Go Back   Home > Forums > Blogs > Bas Horneman's diyAudio.com blog
Solid state Adventures into the solid state world. I guess the main reason being to do a reality check and to be able to talk about other things than tubes.
Old
A few pcb's more...
Posted 7th December 2009 at 09:40 PM by Bas Horneman (Bas Horneman's diyAudio.com blog)
Updated 7th December 2009 at 09:58 PM by Bas Horneman
With a dayjob and other "stuff" in my life. I don't always feel like conquering the cold and messy shed to go do some drilling. But I usually have other projects running parallel that I can do something on. Pictured here is the Pass B1 and the lightspeed pcb's. Stuffed...primarily because..... that way I won't loose parts in my messy hobby room.
The Kendeill caps were too big for the B1 board. So I soldered the neg terminal to the neg hole in the pcb and wired the plus to the positive rail.
The wires of the 10uF cap I bent to go beneath the pcb and almost touch. I did this on purpose because I have some 0,22uF smd caps that will act as bypass for the Audyn polyprops. They will go between them wires there.
Click the image to open in full size....
Click image for larger version
ID:	77   Click image for larger version
ID:	78   Click image for larger version
Bas Horneman's Avatar
diyAudio Moderator Emeritus
Views 1576 Comments 0 Bas Horneman is offline
Copyright 1999-2017 diyAudio
