Go Back   Home > Forums > Blogs > abraxalito
Rate this Entry
Using Audacity to do NOS droop correction
Posted 29th April 2012 at 03:36 AM by abraxalito
If you have a NOS DAC (like a Metrum) and are curious to hear how it sounds with the zero-order hold corrected, here's a fairly simple way to try out my 3-tap filter using Audacity.
Load up the file you'd like to process and make two duplicates (select original and use Ctrl-D) - we'll call them A and B. We need to apply delay and gain to A and B which we do with Audacity's time-shift button (in the group of 6 tool buttons to the right of the transport buttons) and the 'Effects - Amplify' feature. A is shifted one sample to the right, and B, two samples right. I've shown how this looks with a mono chirp signal in the first image.
The gain is input into Audacity in dB so 0.15 becomes -16.5dB and 0.026 is -31.7dB. These are the gains for A and B, respectively. A needs to be inverted too - use 'Effects - Invert'. The second screen grab shows how it looks after these operations (I hid the device toolbar to give more space for waveforms).
Having processed the two duplicates then selecting all 3 tracks followed by 'Tracks - Mix and Render' gives the result in the 3rd pic. The sweep (called 'chirp' in Audacity) here is 1kHz - 20kHz, linear steps.
Click image for larger version
ID:	654   Click image for larger version
ID:	655   Click image for larger version
Views 1285 Comments 0
Total Comments 0
Comments
Copyright 1999-2017 diyAudio
