Go Back   Home > Forums > Blogs > abraxalito
Rate this Entry
Just for fun - an ultra-low impedance AIF
Posted 18th June 2014 at 11:40 PM by abraxalito
DIYing high enough Q inductors for anti-imaging filters is a bit of a challenge so here's another way to approach this. I found its possible to build very high Q inductors by simply slipping ferrite beads over a fairly thick copper wire. The limitation though is that the beads I have offer about 1.2uH per bead. So making a ferrite bead version of a 660uH inductor will call for over 500 beads - rather impractical.
To make such a ferrite bead inductor filter a practical possibility its necessary to work at a much lower impedance. I've taken a 1ohm working impedance inititally to develop this filter. Now the largest inductor just needs 10 beads. Given this very low impedance the post-amplifier's noise performance becomes rather a challenge - but a transformer will probably do the trick nicely. I plan to try this with a 1:7 step up trafo and see how it goes.
This kind of filter is probably very suitable for DACs with higher output current - the communications type usually give 20mA so I'll investigate whether the inductors maintain their high Q at such currents.
Click image for larger version
Posted in Uncategorized
Views 637 Comments 0
Total Comments 0
Comments
Copyright 1999-2017 diyAudio
