Go Back   Home > Forums > Blogs > abraxalito
Rate this Entry
Simple anti-imaging filter
Posted 28th May 2013 at 04:57 AM by abraxalito
Updated 4th June 2013 at 07:34 AM by abraxalito
If you're curious to see how an anti-imaging filter affects the SQ of your NOS DAC but have been hitherto put off by all the coil winding involved, then this circuit might be just the ticket.
I was curious to see how well just two inductors could do and it turns out not at all badly - there's about 23dB stop-band rejection here and the 10mH inductors are off-the-shelf Fastrons. The capacitors can be all 1nF 0805 C0Gs - just buy a strip of 40 and use parallel and one series combination.
I intended to build one and listen to how it fares against my more complex efforts...
Update - a quick listen and its clear on switching back to the original filter that this new filter's noise floor isn't as low. That's not directly perceived as a rise in hiss mind - this is the subconsciously perceived noise floor which translates to more attention given to the music. So I'll put the two inductor filter aside and work on slightly more complex filters next.
Click image for larger version
ID:	1081   Click image for larger version
Views 920 Comments 0
Total Comments 0
Comments
Copyright 1999-2017 diyAudio
